Club Arnage => Help => Topic started by: pretzel on January 28, 2004, 12:22:45 am
Title: Error Message
Post by: pretzel on January 28, 2004, 12:22:45 am
FAO Chris Considine or maybe a Moderator?
Got the following text on my screen when attempting to quote and reply to a message on a thread on this section of the forum. There were a whole lot more lines than this but didn't want to post a VERY long message.
Each line contained the same start the only difference on each line was the line number quoted.
Not a server problem I hope?
Warning: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) in /home/www/club-arnage.com/html/yabbse/index.php on line 53
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) in /home/www/club-arnage.com/html/yabbse/index.php on line 53
Warning: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) in /home/www/club-arnage.com/html/yabbse/index.php on line 54
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) in /home/www/club-arnage.com/html/yabbse/index.php on line 54
Title: Re:Error Message
Post by: jpchenet on January 28, 2004, 09:11:35 am
Lots of use of the word "Sock" there Pretzel!!!  What were you doing at the time??   ;D
Post by: gibberish on January 28, 2004, 09:59:25 am
Yeah, I noticed that...........Odd ;)
Post by: pretzel on January 28, 2004, 02:32:53 pm
I'm beginning to wish I hadn't posted this..... Still if you can't take a joke you shouldn't have joined I suppose.
I don't normally have a 'sock' problem but on reflection if I did then this forum is the ideal place to sort it out.
Bring on the sock advice........
Post by: gibberish on January 28, 2004, 07:50:38 pm
Ahem...........now then (and I've never done this before, BUT)
Taking the sock in the right hand, and steadying the ***** with the left, gently..........Oh Lord NO..........I can't do this :-X :-X :-X :-X
Post by: smokie on January 28, 2004, 07:52:56 pm
Just a hunch - do you have a problem with your MySQL server?
Actually, it looks like a server-side message, hopefully Chris Considine will pick it up and advise...
Post by: jpchenet on January 29, 2004, 01:48:04 am
Ah, so Chris is our "sock" expert?!?!  ;D ;D ;D ;D
Post by: pretzel on January 29, 2004, 09:11:37 am
Thanks Smokie, I too guess it's on the server side as I was accessing from a non-networked PC at the time.
Additional note for Chris Considine - I have not experienced this problem since 28th January.
