Author Topic: Delta Wing Project  (Read 82392 times)
Offline Kristof
    • Raceshots.be
Re: Delta Wing Project
« Reply #75 on: March 13, 2012, 01:27:08 pm »
That looks to me like it has 4 wheels in total....
??? I thought it always has had 4 wheels - never 3.
Me too ...   Never read anything about only 3 wheels (otherwise Morgan might have a go at LM with their 3-wheeler :D)
Offline Rhino
  • Team Booze'n'tabs
« Reply #76 on: March 13, 2012, 01:45:15 pm »
http://www.tyrepress.com/News/24404.html
4 tyres just very narrow front ones.
« Reply #77 on: March 13, 2012, 02:16:48 pm »
First run out now on you tube. Well it goes round corners........... ::)
http://www.youtube.com/watch?feature=player_embedded&v=3wlQAvEfmeI
Looking forward to seeing it run in June, :-X
Offline jimclark
  • (nothing more needs to be said)
    • Le Mans Weather
« Reply #78 on: March 13, 2012, 04:48:20 pm »
You thought right... ;) ;)
"Those were the days my friends. We thought they'd never end..."
jimclark
Offline lofty
  • joint european drinking initiative
« Reply #79 on: March 13, 2012, 06:35:46 pm »
sensible to test on massive car park with nothing to crash into.i couldnt get sound but looked fast enough.bit like riding a bike but with 2 sidecars.
J.E.D.I.
i dont want to be in a club
i want to be in a gang
or perhaps a drinking order
« Reply #80 on: March 13, 2012, 06:52:10 pm »
Inside the DeltaWing...
Those look like VERY narrow tyres..
http://auto-racing.speedtv.com/article/photos-inside-the-deltawing/
« Last Edit: March 13, 2012, 06:55:13 pm by Grand_Fromage »
« Reply #81 on: March 13, 2012, 07:08:08 pm »
Every time I see it, it brings to mind Evel Knievel's Sky cycle.
Well there's some hope, that didn't fly.
« Reply #82 on: March 13, 2012, 07:13:46 pm »
High speed front puncture or blowout, and I would not like to be driving.
If it does run at Sebring could someone look to see if the front tyres are still fixed with 3 studs, seems odd, rear tyres are fitted with one standard nut.
Technical reason?
« Last Edit: March 13, 2012, 07:18:53 pm by Barry »
« Reply #83 on: March 13, 2012, 09:04:42 pm »
Cutting edge of technology... with a pair of Citroen 2CV 3-stud wheels on the front.
Technical reason?
« Reply #84 on: March 13, 2012, 09:59:12 pm »
Technical reason?
« Reply #85 on: March 13, 2012, 10:54:02 pm »
I think they've gone for 3 nuts for lightness - no need for a big stub axle/hub assembly. There's no (visible) suspension. Only 25% of the weight is at the front, and thats about 120kg, or 19 stone.  And it all has to fit under the bodywork ;D
The trouble is weight transfer.  When you put the brakes on, Newton's laws put a lot more weight on the front and those skinny little Michelins will complain.  Likewise, drop the clutch and it might wheeley.  And approaching these extremes will be lethal
Offline Snoring Rhino
« Reply #86 on: March 13, 2012, 11:16:08 pm »
I always thought the key to a good set up was balance cross the axis's and the load transfer when going around corners (Hence off-set Indy cars). if this works it will throw out all common thought and wisdom on race car set up. It must have a pretty trick diff to help pull the front around. If thats the case,hope it doesnt fail.
Offline jimclark
    • Le Mans Weather
jimclark
Offline Boorish Grobian
« Reply #88 on: March 14, 2012, 06:28:37 am »
Jesus H Christ, seriously...
Looks cool is a long way from being a real racing car.
« Reply #89 on: March 14, 2012, 08:44:46 am »
I'm sure it will be fast down the Mulsanne, no rear wing to hold it back.
Just hope whoever is driving it can hang onto it over the bumps and ruts. With almost no visible front suspension and therefore little damping at the first sign of a bump the whole think will just launch and steering control will go.
The crumple zone must also be compromised by having those wheels so close to together, head on wont they be pushed back into the drivers feet?
I am sure there are some very clever people involved who must have done the sums so are confident it wont be the death trap it looks like.
