Poll
WILL IT EVER WORK AGAIN?
No
Yes
Put it in a Microwave!
Author Topic: LAP TOP  (Read 8688 times)
Offline wishy
  • Shed's do track days!!!!!
Re: LAP TOP
« Reply #15 on: February 12, 2007, 10:37:49 pm »
If you havn't a soldering iron ........bring it down with you and ask Brian to do his fire breathing again.....that might do the job
Offline Canada Phil
  • The Moose
Re: LAP TOP
« Reply #16 on: February 13, 2007, 04:50:29 am »
Update
By the way, how do you use a solder iron? is it like a blow tourch?
Hi No Panic,
                   Soldering Iron is a completely different animal to the blow torch ::) Firstly the torch uses flammable gas and has a lovely subdued roar to it. Will burn anything in it's path. The soldering Iron on the other hand operates onPFM ( otherwise know as electricity) and is difficult to know when it is ON. A sure way of know it is ready to solder is to take the tip between you thumb and forefinger.
If it hurts like hell its ready ;D
Re: LAP TOP
« Reply #17 on: February 13, 2007, 10:11:08 pm »
Update
Laptop resoldered, rebuilt, all complete.
Switched on - and runs ! ..........almost
But no keyboard functions !!! - ahhhhhhh
Now to take it all apart again.
Anyway with all the spare screws left over, it should be quicker.
Re: LAP TOP
« Reply #18 on: February 14, 2007, 09:33:22 pm »
UPDATE
The Laptop is complete rebuild, and running OK
and even better only 6 screws left over, I'm sure they did not them in the first place.
Would I do it again, ........ NO.
Next time I let my dog chew it and claim on insurance.
Thanks for all help.
Re: LAP TOP
« Reply #19 on: February 14, 2007, 10:07:37 pm »
I once took a Mini Engine to bits to replace a broken part in the Gearbox.  After reassembly I had a spare Bearing left over.
I didn't have the balls to try it without.  So took it to bits again.  Once I put it all back together it worked.
I did learn on lesson doing that.  Always replace the oil seals
Fortunately it didn't cost me much oil as I sold the car soon after that.
