Author Topic: Help with a malware virus please  (Read 7618 times)
« on: December 26, 2010, 07:51:59 pm »
Hi folks, a Trojan virus called fakespypro appears to have found its way onto my laptop. Dell laptop with windows vista. Mcafee had run out, so thought would download ms security essentials and uninstall mcafee. That worked fine, until I uninstalled mcafee when it was apparent that the malware was preventing all sorts of things running properly.  Run scans with windows security essentials in safe mode and then restart, but it returns. looking at various forums, Is it worth having a go at downloading something like malwarebytes or spybot in safe network mode and then running one of those? Thoughts please....bearing in mind I am not an it pro....ta
mg mark
Re: Help with a malware virus please
« Reply #1 on: December 26, 2010, 09:50:00 pm »
Checked with my son, said download AVG as it finds alot of the virus and its free.
Past experiance has worked for all of us
http://www.avg.com/gb-en/buyav-ppc_1?ctype=ppc_uk_gs_0002_buyav_1&wm_crID=5035958&wm_lpID=28518107&wm_ctID=383&wm_kwID=17360839&wm_mtID=3&wm_content=0&wm_g_crID=6597716679&wm_g_kw=a+v+g&wm_g_pcmt=&wm_g_cnt=0&wm_kw=a+v+g&wm_sd=1
Oh yea, if it works you will owe him a beer at Le Mans this year  ;), as it will be his first Le Mans (if he can manage go, subject to his studies)
« Last Edit: December 26, 2010, 09:51:55 pm by nopanic - neil »
Offline Ade
    • http://www.flickr.com/photos/13953963@N04/
« Reply #2 on: December 26, 2010, 11:19:56 pm »
You could try this http://housecall.trendmicro.com/uk/ as this has worked for me in the past. I also run AVG.
Ade
Le Mans - the how you get there is not quite as important as being there.
Offline clkgtrlm1
  • Le Mans - Follow the Carbon Footprints!
    • num44
« Reply #3 on: December 27, 2010, 12:16:08 am »
Try downloading SpyBot, haven't got a link but google it. It will take a short time to install, but a long time to do the first sweep. Make sure that you select / clean all files
Baldrick, my Lord! But I can change it to Ploppy if it'll make things easier.
« Reply #4 on: December 27, 2010, 10:38:13 am »
There's a great thread here http://forums.majorgeeks.com/showthread.php?t=35407 which goes into massive detail (and links to other OS dependent threads), but the two products they suggest seem pretty good to me - had to use them a couple of times and they always seem to do the trick
SuperAntiSpyware http://www.majorgeeks.com/SUPERAntiSpyware_d5116.html
MalwareBytes - http://www.majorgeeks.com/Malwarebytes_Anti-Malware_d5756.html
Googling fakespypro brings up a lot of so-called removal tools but I'd always start with the products above.
Offline johnhere
« Reply #5 on: December 27, 2010, 02:36:02 pm »
This should sort it out for you download the free version and keep it updated
http://www.malwarebytes.org/
« Reply #6 on: December 28, 2010, 05:41:34 pm »
Thanks for the info folks, plenty to try out there! I'll try and see how it goes. I'm accessing this via an iPhone at the mo until I get back to work, so surfing for info is somewhat limited by the small screen! I haven't worked out getting onto the net via the laptop at present, if I can't any clues as to whether I can download any of the programmes mentioned to another computer, transfer to a disc and then install and run it that way to start with? Also does said Trojan thing actually modify files such that one has to reinstall stuff? Ta,
« Reply #7 on: December 29, 2010, 12:53:15 am »
Mark - by all accounts this is a nasty one, but is treatable successfully with Malwarebytes Anti Malware,  linked to above, which you should be able to download as an .exe file and burn to disc on another computer to run on the infected computer.
« Reply #8 on: December 29, 2010, 01:11:25 am »
VMT, have managed to find the way to successfully back up, virus free, various working files, photos etc created since my last back up (thankfully relatively recently) onto a remote drive, so I can now have a go with malwarebytes or similar and not lose any personal stuff. Failing all else there is the time honoured "format c, yes, are you sure, yes" method as the ultimate weapon in the armoury!
« Reply #9 on: January 01, 2011, 11:42:17 am »
Folks,
Thanks for the advice and pointers.  I managed to download Malwarebytes onto another computer, copy it, load and run it on mine - it found and removed all sorts of stuff, including the main culprit, which was Fakespypro. However, that returned after restarting, and did the same again after another run through, so it had obviously embedded itself thoroughly.
On the basis that I had already backed up all my working files before it appeared, had loaded relatively few applications, and my expertise had run out, I took a deep breath and ran the Dell factory restore option, which reformats the hard drive and reinstalls the system to the original spec.
Thankfully, this has worked and got rid of the problem completely, so I'm back up on line and firing on all cylinders now, with just a few settings to change and a slack handful of stuff to load back up.  The experience certainly reinforced the value of backing up personal files regularly.....
Thanks again,
Offline johnhere
« Reply #10 on: January 01, 2011, 03:15:08 pm »
Pleased its all sorted
That will teach you not look at porn on the net lol
Offline landman
    • S-Max Owners Club
« Reply #11 on: January 02, 2011, 06:24:38 pm »
Folks,
Thanks again,
Mark,
You might consider using something like DropBox or Humyo as a constant backup system.
Not that expensive so long as you don't store lots of GB's.
Rgds,
Paul.
« Reply #12 on: January 03, 2011, 10:54:36 am »
Buy a Mac
1. They generally are a lot safer to run as far as viruses are concerned
2. You have a built in back-up system called Time Machine which only needs an external hard drive, if you have ever seen how this works you will be impressed.
3. They do not fall over all the time like a PC
4. They look good
Offline landman
    • S-Max Owners Club
« Reply #13 on: January 03, 2011, 10:58:55 am »
Buy a Mac
4. They look good
I wasn't going to mention Mac in case the Mac haters start up again.
Paul - posted from his MacMini [feeling smug]
Offline nickliv
« Reply #14 on: January 04, 2011, 09:07:00 am »
Buy a Mac
1. They generally are a lot safer to run as far as viruses are concerned <Although the tide is turning, and it is easy to protect yourself from viruses with a number of very good, and FREE PC programs>
2. You have a built in back-up system called Time Machine which only needs an external hard drive, if you have ever seen how this works you will be impressed. <Fair enough, but back ups aren't rocket science. Most USB hard drives come pre packaged with backup software now>
3. They do not fall over all the time like a PC <used to>
4. They look good <Shouldn't this be at number 1? ;-)>
5. They'd better be good. Have you seen the price of the bloody things?
If I had all the money I've ever spent on drink, I think on balance, I'd probably spend it on drink.
